Greg
What is the process to show movies on a pixel matrix?
Hey Dr, it's been a while. Is there a video on this or a thread to follow? I haven't done any sequencing for a while and started back this morning. I'd like to investigate playing movies within HLS.DrNeutron said:HLS also has this capability.
Once you use ffmpeg or After Effects to convert the video clip into .png images (same procedure as talked about above), you would just select "convert folder of PNG images to effect" and you would have an effect to place on a pixel plane. You can then manipulate it and move it etc ....makes things very easy.
I tried this method (multiple times) but my video (or series of png files) plays back slowly. I tried a number of different settings within the ffmpeg command prompt (tried 20fps, 25fps, 50fps, 10fps) but to no avail. I am currently using xLights 3.6.15. Any assistance would be greatly appreciated.Gilrock said:You could do that since xLights3. With xLights4 it will be easier if you need to align the audio since you can just drag the picture effect with respect to the audio waveform. Basically you use ffmpeg which is included with the xLights installation to break up a video into still frames. Each frame ends with -1, -2, -3, etc. Then use the picture effect and point to the first frame and it will automatically advance through the frames to create the sequence. I have this video where I did this in version 3. You can do the same basic steps with version 4 just use the Picture effect:
http://www.youtube.com/watch?v=j9IAfYdYzwU
I just threw together my 1st matrix this weekend (6 x P10 panels = 3072 pixels) and just have to mount them to hardboard so I have a way to hang it to do more testing. Once I have it sorted, I'll get back to you on what works best. Last year was more or less making each .png image separately and sequentially (same as cartoon animation) and then using HLS to create an effect from the .png images. Very simple, but some trial and error to get it to play at speed I wanted.Habbosrus said:Hey Dr, it's been a while. Is there a video on this or a thread to follow? I haven't done any sequencing for a while and started back this morning. I'd like to investigate playing movies within HLS.DrNeutron said:HLS also has this capability.
