daunce
I have FPP (with P10 panels), and a Falcon f16v3 with the rest of my models.
Using FPP in standalone mode, some sequences work (animation), while others (musical) don't. FPP outputs to all lights when in Display Testing, and each individual model works when selected, so I know the wiring and universes/channel numbers are correct.
In the Display Testing page, the musical sequence works, but it doesn't play from the Status Page. When I press play on the musical sequence, the elapsed time and remaining time don't change.
I did have other animated sequences that didn't work, but after some fiddling I was able to get it to work.
I can't work out why some work, but not the others. If they're created from the same xLights config, and uploaded using FPP Connect, what would cause one to work, while others don't?
Are there any gotchas when using musical sequences in FPP? In FPP Connect, I've tried FSEQ v2 and v2 sparse.
FPP is running 3.4.2.
[Edit. Just changed a musical sequence to animation, and sent it to FPP. It works fine in FPP without the mp3. The Audio plays ok in xLights.]
