My 2012 Inaugural Flash Fest
ԆцряєсϮ
Botanic Ridge
OK Heres a list of all the things I hope to acheive this year in turning my now static display into something that goes blinky flashy to doof doof!
Actually now that I've listed it all down I'm glad I've got 12 Months to do it! :D
Hang on.... make that 10 months :eek:
Additional elements I need to build/source
Project 1: 3 x RGB Dancing Arches
Progress: Waiting on delivery of strip Strip now on deck, some cutting and soldering has begun Complete
Project 2: 10 x F.A.S.T snowfall lights
Progress: Waiting on delivery of bits- Still waiting 5 Built so far and just waiting on Tubes
Project 3: 1 x 30 Channell 3 colour Led String Tree
Progress: Not started yet
Project 4: 5 x RGB window surrounds
Progress: Waiting on delivery of bits Bits delivered, awaiting buildage
Project 5: 1 x Tune To sign
Progress: Waiting on delivery of bitsBits delivered, awaiting buildage
Project 6: Build some RGB Rope lights to restring my existing 240V reindeer frames ( x 2)
Progress: Waiting on delivery of bitsBits delivered, awaiting buildage and also investigating mini pcb's for housing the leds
Project 7: 2 x RGB VU meters (using the 5' Tint Tubes )
Progress: Started initial testing of mounting strip into the tubes, awaiting delivery of controllers Controllers delivered and modified (Replaced xlr's with RJ45 sockets) Strip has been cut and wired and is ready for mounting Complete
Project 8: Learn how to use LSP to make it all flash :D
progress: Started doing some basic sequences, waiting on delivery of hardware to continue testing.Have successfully mad some strip go blinky flash so all ready to go, basic sequences have started
Project 9: Cut up all my existing BigW strings so they can be Controlled.
Progress: Not Started yet
Project 10: ACL LED strobes.
Progress: Group buy not finished yet
Project 11: 10 x RGB 12 LED 5050 wall washers
Project 12: PIC programming
Progress: Complete, have now mastered the art of programming my own pic's
8) Onwards and Upwards! 8)
Rod
ruprect88 said:
Heres a list of all the things I hope to acheive this year in turning my now static display into something that goes blinky flash doof doof!
Project 1:
Here's hoping there is more to the story. LOL
I like your style, keep the list short its easier to accomplish!
Wow, you're going in hard to start off with! I like the sound of the VU meters, how big will they be? Will they be actual VU signals or just sequenced to look like it?
Good luck with it all!
Graham
1500 tall and 5 sections in each, although I have some 1800 tubes coming soon so I'll have to see which look better.
At this stage just sequenced to look like it, it will depend on how much I get my learnin on as the year progresses.
Ok now the fun begins. :D :D
Goodies have finally arrived. 8)
Project 8 update ...... Success
after 30 mins of set up and stuffin around I have successfully made a string of RGB modules blinky flash through my DR4 and one of Rays 3ch controllers
in the words of a great Kazakhstanian
I am excite....... great success - High Five!
Made some good progress today, started cutting up some strip ready for the VU meters and arches.
Also modded all of my27Ch boards by replacing the xlr's with RJ45's. :D
I love it when a plan comes together! 8)
Great Work any chance of a little more detail please, ie strip type, what are you running E1.31 or Dmx etx for us more cautious folk this is good to learn from!!
cheers Boof63 :p :p :p
No Probs
I've mounted 5 x 300mm sections of dumb RGB strip on top of some 25mm Conduit, then Ive mounted the conduit within the tint tube. This way it keeps the strip approx 50mm from the front of the tube. I found this to be about where the best light diffusion occured (too close and you can see each individual led).
Each section is cabled with 4 core security cable (run down through the pipe) and terminated to a Ray Wu 4 core w/proof connector.
For the test vid I just hooked up 5 female plugs to one of Rays 27ch boards which is driven by a j1Sys DR4 EthConGateway.
The flashy bit was done in LSP using the sonoFX effect tool set at about mid range in the sonogram.
Hope this all helps, all the ideas and info I got from this site so happy to put back :D
