My Coro Matrix
zoobmarine
Inspired by Holiday Coro Matrix, I decided to do some mods, here are some photos of the layout, its 7x10 squares, and will have 12mm Pixels, as soon as im done with lights and some sequence test patterns I will update with photos, in the meantime here are some.
Sorry about that, wrong link from dropbox, here they are
Looking great, how many LEDs do you intend on putting in each section. you may find one 12mm pixel may not be bright enough because David Moores version uses the modules which are 3 x 5050 LEDs, so a bit of light output difference that you may have not considered
HI, i used the 6 led half circle leds (12v , 50mm) for my coro stars and they worked a treat. one each per star
maybe they might suit better?
cheers Boof
Link is Here
Looks good.
What's the differance between the top and bottom matrix?
Top the pixels are seen (hot spots) and the bottom is very even lighting.
