My First MegaTree
Discussion in 'Mega, Mini, Spiral & Pixel Trees' started by fmt1962, Feb 1, 2015.
  1. fmt1962
    fmt1962 New Elf
    Dec 28, 2014
    40
    13
    Forster
    I have just finished building the frame for my first 2D mega Tree and thought I would share the construction.
    The frame is made entirely of aluminium and will have 5v 30 pixel/m strip
    This is the framework being cut and sized
    Welding the frame together using MIG welder.
    Mega-Tree-2D-Pre-Assembly-Welding-1.jpg Mega-Tree-2D-Pre-Assembly-Welding-2.jpg
    Completed frame ready to paint
    I finished painting it today and look forward to adding the pixel strips soon.
    Starting to get exciting now...... :)
  2. jb09
    jb09 HOHOHO NOT LONG TO GO
    Jul 27, 2011
    87
    0
    Berrima sheidow park
    Looks good
  3. lizardking
    lizardking IT IS STILL ALL BENS FAULT
    Dec 26, 2014
    416
    0
    Gold Coast
    awesome did you just use the aluminium wire in your mig welder might look at that way for a matrix
  4. OP
    OP
    fmt1962
    fmt1962 New Elf
    Dec 28, 2014
    40
    13
    Forster
    Yes and no.... feed wire is aluminium, but it must have 'Argon' shielding gas. So you need a full gas mig welder with Argon. Cleaning is super important too, any contaminants will upset the weld badly, cleaning with stainless steel brush just before welding does the trick nicely.
    The nice thing about this frame is it is ultra light and solid, with luck it should be durable and survive the coastal winds we get here in summer, time will tell.
  5. fasteddy
    fasteddy I have C.L.A.P Global Moderator
    Apr 26, 2010
    6,639
    70
    Looks great
  6. dale82
    dale82 Senior Elf
    Nov 19, 2010
    568
    1
    Kingaroy
    Looks great Daryl. once you get lights on it you can build me some gear! lol
  7. gerry
    gerry Senior Elf
    Dec 19, 2012
    805
    5
    Surrey Hills,Melbourne
    Looks good Daryl.
  8. Fing
    Fing Full Time Elf Generous Elf
    Dec 31, 2014
    398
    45
    Muswellbrook
    Most impressive, what size is it ?
    Fing
  9. buzzdude
    buzzdude Full Time Elf
    Oct 7, 2013
    155
    3
    Chrinside Park, Vic
    Very professional looking. Well done.
  10. mborg10
    mborg10 Michael Borg
    Dec 28, 2011
    1,446
    1
    claremont meadows
    Looks great. Are the legs 2.5m long. Look forward to seeing some lights on it
  11. OP
    OP
    fmt1962
    fmt1962 New Elf
    Dec 28, 2014
    40
    13
    Forster
    Thanks for all the supportive comments, I am really excited to be building my first real hand made xmas display.
    The tree has 2.5m upright bars, so I can use one 5m strip for 2 legs.
    The center supporting bar is 3m x 25mm x 25mm aluminium box section. This gives enough extra length for a base mount and a for the star on top.
    The individual bars are 12mm x 3mm x 2.5m with the supporting cross bars being 19mm angle.
    I will be using 5v, 30 LEDs per meter black strip lights.
    I decided to use aluminium for the light weight and strength, and also welded rather than pop rivets for strength too. It is now painted black to reduce any reflections. I like my lights to be as invisible as possible until they come on.
    All you guys on here are so inspirational, it is awesome to see all the stuff you have done and sharing all your build info... got me totally excited to have a go myself.....
    Thanks guys...
  12. bluzervic
    bluzervic 65,768 Channels, 185 Universes
    Dec 31, 2011
    533
    27
    Fremont, Calif.
    What does one of these run ?
    I did Arc and gas welding a while back, so I might be willing to give it a try.
    Will this welder work with 1/4 inch wireframes as well or would you recommend a different welder
    -Blu
  13. Gilrock
    Gilrock Full Time Elf
    Jan 4, 2013
    397
    14
    Tucson, AZ
    Nice. I was planning to make something similar but I need it to be 5m long so I will probably need to design it so it can break down. I also have some other ideas because I need it to be a tree shape in December and a horizontal rectangle shape for May. So I was think I could have the ends bolt into cross beams and then I remove all the bolts and rotate the bars and reattach to new cross beams with different spacing when I need to change the orientation.
  14. Bird
    Bird LOR user
    Nov 8, 2011
    1,747
    2
    Cincinnati, Ohio, USA
    Very nice
    Jealous of your talent ;)
  15. OP
    OP
    fmt1962
    fmt1962 New Elf
    Dec 28, 2014
    40
    13
    Forster
    I am not a welding expert, this is my first aluminium job ever, but it went really well.
    Mig Welders are capable of welding very fine and thin material, this is one of the main features of these machines.
    I am sure there are others here that could offer much more advice than me on this subject.
    Now if you want some advice on really big computers... then I might be able to help out... :)
