bob_moody
Okay .. cruddy subject line, but here is my request...
I currently have a J1Sys D2. love it, use it and will stay with J1 for pixels ..
2013 plans are:
Merry Christmas sign - 219 (26MM TM1804) pixels in a dot matrix type format. An upgrade to what I had and lost in 2012... http://www.aliexpress.com/item/26mm-diameter-TM1804-LED-pixel-module-3pcs-5050-RGB-SMD-LED-DC12V-input-IP68/597351990.html
8 CoroCanes - 128 (8 canes with 16 rectangular WS2811 pixels in each) pixels ( http://www.aliexpress.com/item/WS2811-IC-Pixel-RGB-Waterproof-5050-3LED-module-light-ideal-sign-box-lamp-100pcs-lot-free/697981926.html )
4 Arches - Using either Strip or maybe the rectangular pixel modules I show above. I would liek to use 2 strips w/ each strip making 2 arches (controlled in the middle?) ( http://www.aliexpress.com/item/5m-led-digital-strip-DC12V-input-WS2811IC-256-scale-10pcs-IC-and-30pcs-5050-SMD-RGB/568458133.html )
My delima is how to drive this...
1. Can it all be driven from a single controller? P2 or P12? If I understand the arches correctly, the 2 strips would max out the P2 in 2 universes? n
2. Would 2 P2's be a better solution? One for the sign and the CoroCanes and one for the arches?
I am open to any and all suggestions..
I want to place an order with Ed, but I'm behind the curve on selecting the needed controller.
Thank you all,
Bob
2013 plans are:
Thank you all,
Bob
