New ECG-P2X annoucnement and more
Benslights
Elderslie
ECG-P2X – the new super P2, same size, same case, more features
this is a New release from Ed that has been specially announced at the Australian Sydney Mini.
Thanks Ed
Ethernet – 10/100 Ethernet Interface board (prototype was built on an EtherCat board with dual connectors, production will have a single RJ45)
EtherCat – 10/100 EtherCat interface board – EXCITING!!
WiFi – 2.4Ghz commercial grade WIFI interface board (prototype only has a chip antenna, production will include an SMA screw in antenna connection for a simple “rubber ducky” external antenna)
What they are:
The ECG-P2X series of boards is our newest design for dispersed pixel controller. It consists of our new ECG-P2X board, along with 3 different optional network interface boards.
The ECG-P2X is the base board. It can be used as a stand-alone controller with no communication or can be enhanced by placing a network interface board on top. The ECG-P2X includes a microUSB interface for programming and configuration using our j1UBL software. It includes a uSD connector for local sequence storage along with a battery backed up Real Time Clock for scheduling. It includes two outputs along with a fused 7.5A power distribution for each output. Each output can drive either: 1 or 2 single-ended three wire pixel strings, 1 four wire pixel string, 1 differential three wire pixel string, 1 dmx output, or 1 renard output. Each output has a single 7.5A DC power output. In the case of dual three wire strings the power would be shared. Each port can transmit a maximum of 4 universes split among the attached strings.
Optionally a network interface board can be attached on top of the P2X. Each interface board includes a personality and serial number chip that is auto-detected by the P2X to configure the software to match the interface.
The interfaces include:
J1LAN-ENET – a standard 10/100 Ethernet interface
J1LAN-ECAT – a 10/100 EtherCat multi-drop interface. More info below.
J1LAN-WIFI – a 2.4Ghz commercial grade WIFI interface. Includes chip antenna or external antenna connection
Tentative Pricing: in US Dollars
ECG-P2X - $80
J1LAN-ENET - $20
J1LAN-ECAT - $30
J1LAN-WIFI - $30
Optional Case - $10
We expect to place production orders in early June, production completed by July 1st.
  • Attachments_201665.zip
