new necg-DP2 coming to clap supplies soon
Benslights
Elderslie
So what is a NECG-DP2
The dp2 is a p2 and a d2 merged together and shrunk to fit in the palm of your hand. It comes in a translucent blue plastic case with the rj45 on one end, a microusb and expansion port on one side and a 6 pin minigreenie (2.54mm pitch) on the other end.
The 6 pins are:
1 - ground
2 - port1 clock, port1b, port1-
3 - port1 data, port1a, port1+
4 - port2 clock, port2b, port2-
5 - port2 data, port2a, port2+
6 - +V input 5v or 7v-24vdc
There are jumpers for voltage selection just like p2/d2.
There are output jumpers that select either 2 single ended or a differential pair for each port.
If in single ended: each port can drive either a single 4wire string using clock and data or it can drive 1 or 2 3wire strings. If 3wire the primary string (A) goes over the data wire and the secondary string (B) goes over the clock wire.
If in differential: each port can output dmx, renard, or a single string of 3wire differential to drive a ppr 100s of feet away.
Both ports are totally independent but can only do one mode/string type each.
DMX and renard are limited to one universe per port.
Pixel outputs can have 2 universes per string or a total of 4 universes per port.
Our usual html configuration screens, ubl, effects, strobes, etc.
It can be powered fron the minigreenie or over the microusb (5v).
will be coming in at $83.50 Australian
will let you know when in stock
Just got mine today! Can't wait to test it out this weekend and see how she flies!
It certainly is tiny. You could fit 3 of these inside the case of the regular P2 and that is with their cases on!
I also picked up a P12D to test out and run with as well.
I sure need to study a lot now it seems! :eek:
Here is the PDF for the new DP2........
https://onedrive.live.com/redir?resid=5830318B7C09599D!4766&authkey=!AAFRmLo_Fd2G3dY&ithint=file%2cpdf
No problem. Keep in mind the new Dp2 board speed works in the hundreds not the thousands. I think I am running mine around 400 VS the 3500 I was running my original P2 on. ;)
Sorry Andy, I meant that the timing of your post was most perfect! I'll get into the actual timing in the ECG later on! :D
