Hi All,
We've just released a firmware update for the PixLite controllers. Version 1.3.0 now has the DMX outputs enabled as well as a built in test mode. The DMX outputs will work on all controllers including ones from a long time ago (they just have a single output instead of 4 like the more recent ones).
Make sure you download the latest Advatek Assistant as well to configure your controller with. You can get the latest assistant and firmware from here: http://www.advateklights.com/resources/
Test mode works by holding down the "Factory IP" button for 3 seconds after the board is running and then letting go. Single clicks after that will scroll through test modes. Hold down again for 3 seconds to go back to normal operation.
Hope you all enjoy.
Luke
Hope you all enjoy.
Luke
