New Wu Technicolor pixels
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by zman, Dec 4, 2014.
  1. zman
    zman Full Time Elf
    Jun 8, 2010
    100
    1
    Woodinville, WA
    I did a minor search
    Anyone get Ray Wu's next gen TC's? Problems?
  2. JPB
    JPB Full Time Elf
    May 13, 2010
    334
    11
    Glenwood
    Big thread on DIYC
    http://www.doityourselfchristmas.com/forums/showthread.php?t=35572
  3. baelinc
    baelinc New Elf
    Jul 12, 2011
    3
    0
    I purchased 6 strings of 50 technicolor pixels in October. I used them to create 6 arches which played perfectly the saturday I put them up, but sunday we had over 2" of rain. Monday I fire them up to test them and every string had something wrong with them. I ended up replacing 1 - 2 bad pixels in each string by sacrificing one of the strings for parts.
    Just a sample of what 2 strings were doing when they were suppose to be off:
    https://drive.google.com/open?id=0ByrbO4A3OJhJSTladnE5YkVzU0U&authuser=0
  4. fasteddy
    fasteddy I have C.L.A.P Global Moderator
    Apr 26, 2010
    6,639
    70
    Seems like nothing has changed for many users with the repeated issues from last year, doesnt seem like the Gen 2 made any significant improvements which is a big dissapointment
  5. tjames
    tjames New Elf
    Nov 27, 2012
    14
    0
    Detroit
    I had 10 sets of the black ones last year and all 10 sets failed. Ray didn't ship the replacements until the end of Oct, but I got all green this time. I've had them up on the house and running for a couple weeks so far and they were running from the time I took them out of the box until I put them up and haven't had a problem but we also haven't had any rain or large fluctuations in temperature. It is however raining as I type this so we'll see how things fare. My issues last year were primarily with the voltage regulators and those issues seem to be fixed.
  6. arw01
    arw01 Full Time Elf
    Dec 30, 2013
    384
    1
    Eastern Washington
    Whew, I invested in 34 strands of Minleon instead.. Other than some engineering on my side being flawed I've had a bit of rain and no failures :D
    I have a set of the new technicolors, may get them out yet this season, but will make sure they are in the dry!
  7. randallr
    randallr New Elf
    Sep 3, 2012
    33
    0
    Andrews, Texas
    I had bought some last year, but held off. Decided to use them around my driveway this year. Some had clear wire, and some were black wire ones. Ran great for a week then the clear string side started going crazy. Seemed to start at at a certain point, so I would replace a couple right at that point. Then it'd be down the string. Fix those, then it was back before the first splice. Don't know where the noise is getting in. Gave up last night and unplugged them all.
  8. andrewa
    andrewa Full Time Elf Generous Elf
    Dec 22, 2012
    226
    21
    Frankston North, Victoria
    I have 6 strings on the new Technicolor pixles on my roof in a star outline. 2 strings get affected by moisture, and cause the rest of the trailing pixles to blink like crazy, 2 strings have a pixel with 1 colour missing. I used a further 2 strings of these technicolor pixles on my Merry-Go-Round, and have had no problems at all with these 2.
  9. dualbios
    dualbios New Elf
    Dec 9, 2012
    28
    0
    currently have 5 strings of the white up just bought new will find out i guess in the next 2 weeks as lots of rain is predicted
  10. bbayjohn
    bbayjohn Senior Elf
    Mar 4, 2012
    574
    27
    Batemans Bay
    I bought 7 strands of 100. All failed after the first rain. Does anyone know where the water is getting in on these?
    Thanks John
  11. jediknight2
    jediknight2 Full Time Elf
    Aug 30, 2012
    196
    0
    North Carolina
    When did you buy them? Also, how many PIXELS failed...
  12. bbayjohn
    bbayjohn Senior Elf
    Mar 4, 2012
    574
    27
    Batemans Bay
  13. dualbios
    dualbios New Elf
    Dec 9, 2012
    28
    0
    mine which are 4 weeks old are copping some rain atm 3 days so far no issue my tm1804's have all failed so this will be a good test
  14. nutz4lights
    nutz4lights Full Time Elf
    Dec 12, 2012
    305
    0
    Melbourne, Florida
    I was a big part of the thread linked above at DIYC and there are quite a few pictures (some posted by me) of the tear down process on pixels. I live in the state of Florida in the southeastern U.S. and my replacements (green) were fine during the Halloween season and mid-way through November... then we had this one weekend where the humidity got up to around 100% and the temperature was 30-ish all weekend (I know that is nothing compared to some of y'alls temperatures down under, but for most of this country that is warm)... I ended up with condensation in my C9 bulb covers. My bulbs were pointed straight up as that is the way I like them on my roof... and all that condensation dripped onto the interface between the base (the green part) and the LED bulb... my tear downs on failed units showed a ton of corrosion on the top side of the circuit board where the LED is mounted... which basically seals the deal <no pun intended> that there is a horrible seal between the green base and the LED bulb. I shared my pictures with Ray and told him that he really needs to get a THICK conformal coating on these boards.... OR go with a different way of fabricating the base and tying it into the LED...
    -Louie
  15. bbayjohn
    bbayjohn Senior Elf
    Mar 4, 2012
    574
    27
    Batemans Bay
    Thanks Louie. I was thinking the water must be getting in threw the led area. Looks like I will be playing with some silicon to try and fix it.
