ryanatunlock
- Dec 19, 2018
Hi All. Not sure if this is an xLights issue or network issue.
I have FPP running on a PI - Wifi is connected to my home network, and Ethernet is connected to the Falcon F16v3 directly with an ethernet cable. I have routing enabled between the networks.
I have a Windows laptop connected to the home network via WIFI and I can access both the FPP and Falcon web interfaces.
I've setup the Falcon controller in xLights, setup the models and connected to the correct port. I can upload the Output config to the Falcon successfully and the config upload works as I can see it via web admin screen.
I have setup a sequence, but when I hit the play button, there is no action on the pixels.
I feel like I am missing something simple. Any ideas?
