Good afternoon, have an apparent no output to lights, have tried a number of fixes but no success.
Setup is, Falcon 16V outputs wired ground and data only with separate power supply. Have tried a number of models but none work, so will refer to one only a coro star with 96 pixels.
Test sequence of Red, Green Blue and Butterfly pattern, rendered sequence, light bulb on, select play no light on the star.
Reloaded Outputs/inputs to controller no error messages so good?
Saved settings on controller.
Retried to play test sequence no go
Reconfigured output lead from controller port, now set up as 12v, Gnd and data still no lights.
Checked output packets showing 5000 odd.
Hm Ethernet cable ?? fitted replacement cable still no lights
Selected Test mode on controller (colour wash) yes have colour wash on star.
Selected run mode, played test sequence bugger no lights
Had pixel buffer in circuit, removed still no go
Just about run out of ideas so any suggestions welcome
Burto
Burto
