ɟɐsʇǝppʎ said:It works but if trying to move a pixel object like a tree then you have to move a pixel to enlarge the selection box, when you do this it allows you to move the pixel element.
In Mikes example its seems easier because he has used multiple pixels per RGB channel and thus this allows for a larger selection area, but if you have 1 pixel per RGB channel then you need to move this to enlarge the selection area, once moved then shrink back down the selection box so the pixel is back in the correct position.
Hi eddy, giuess I am not understanding. I just tried a matrix split over 16 rgb channels using single pixel per channel and it worked as shown in my previous videos. Perhaps you could make a video showing your process?
Mike
