Eizziljam
I’m Christmas crazy!
Hi All, in putting together some props I've needed to "skip" a pixel or two in the middle of the string. Is there a way in xlights or on the falcon to tell the controller to ignore those pixels?
Thank you!!!! I knew there must be a way!I've done this in the model data in xlights. If I needed to skip pixels 6 & 7 the model should look like: 1, 2, 3, 4, 5, 8, 9, etc
The falcon boards can also have null pixels assigned but I've not personally used it, i'm sure there is a video on this however.
Do you know how to do this if the pixels are at the end of a string? Say I've got a model that uses 48 nodes and i want to ignore 49 and 50 and it's then daisy chained to another model?I've done this in the model data in xlights. If I needed to skip pixels 6 & 7 the model should look like: 1, 2, 3, 4, 5, 8, 9, etc
