Nutcracker 3.0.19 released. Bug fixes for crash on exit, empty export files.
smeighan
4217 Greenfinch Dr CO 80126
Release 3.0.19 is found http://nutcracker123.com/nutcracker/releases/
Release 3.0.19 release notes
NOTE!! This release will modify your existing xml sequence files to correct for missing attributes that caus ethose annoying errors. Please backup all your xml files into a safe place.
3.0.19: Jul 17,2013 - Bug Fix: Crash on exit, fixed
- Bug fix: Empty export files (LOR, hls,vixen,conductor), fixed
- Enhancement: When reading in your sequence, missing attributes will be added if your file is from pre ver 18.
NOTE!! Please make a backup of all your xml files. This release will be fixing your sequences, protect yourself.
Here is a short video of how to make copies of your Nutcracker files: https://vimeo.com/70521761
Here is a table of theattributes that might need to be added into your xml file if your version is older than 18.
missing = missing + wxT("|ID_SLIDER_Brightness|ID_SLIDER_Brightness=100");
missing = missing + wxT("|ID_SLIDER_Contrast|ID_SLIDER_Contrast=0");
Meteors1 = Meteors1 + wxT("|ID_CHECKBOX_Meteors1_FallUp|ID_CHECKBOX_Meteors1_FallUp=0");
Meteors2 = Meteors2 + wxT("|ID_CHECKBOX_Meteors2_FallUp|ID_CHECKBOX_Meteors2_FallUp=0");
// Lots of variables to check for text effect
Text1 = Text1 + wxT("|ID_TEXTCTRL_Text1_1_Font|ID_TEXTCTRL_Text1_1_Font=");
Text1 = Text1 + wxT("|ID_CHOICE_Text1_1_Dir|ID_CHOICE_Text1_1_Dir=left");
Text1 = Text1 + wxT("|ID_SLIDER_Text1_1_Position|ID_SLIDER_Text1_1_Position=50");
Text1 = Text1 + wxT("|ID_SLIDER_Text1_1_TextRotation|ID_SLIDER_Text1_1_TextRotation=0");
Text1 = Text1 + wxT("|ID_CHECKBOX_Text1_COUNTDOWN1|ID_CHECKBOX_Text1_COUNTDOWN1=0");
Text1 = Text1 + wxT("|ID_TEXTCTRL_Text1_2_Font|ID_TEXTCTRL_Text1_2_Font=");
Text1 = Text1 + wxT("|ID_CHOICE_Text1_2_Dir|ID_CHOICE_Text1_2_Dir=left");
Text1 = Text1 + wxT("|ID_SLIDER_Text1_2_Position|ID_SLIDER_Text1_2_Position=50");
Text1 = Text1 + wxT("|ID_SLIDER_Text1_2_TextRotation|ID_SLIDER_Text1_2_TextRotation=0");
Text1 = Text1 + wxT("|ID_CHECKBOX_Text1_COUNTDOWN2|ID_CHECKBOX_Text1_COUNTDOWN2=0");
Text2 = Text2 + wxT("|ID_TEXTCTRL_Text2_1_Font|ID_TEXTCTRL_Text2_1_Font=");
Text2 = Text2 + wxT("|ID_CHOICE_Text2_1_Dir|ID_CHOICE_Text2_1_Dir=left");
Text2 = Text2 + wxT("|ID_SLIDER_Text2_1_Position|ID_SLIDER_Text2_1_Position=50");
Text2 = Text2 + wxT("|ID_SLIDER_Text2_1_TextRotation|ID_SLIDER_Text2_1_TextRotation=0");
Text2 = Text2 + wxT("|ID_CHECKBOX_Text2_COUNTDOWN1|ID_CHECKBOX_Text2_COUNTDOWN1=0");
Text2 = Text2 + wxT("|ID_TEXTCTRL_Text2_2_Font|ID_TEXTCTRL_Text2_2_Font=");
Text2 = Text2 + wxT("|ID_CHOICE_Text2_2_Dir|ID_CHOICE_Text2_2_Dir=left");
Text2 = Text2 + wxT("|ID_SLIDER_Text2_2_Position|ID_SLIDER_Text2_2_Position=50");
Text2 = Text2 + wxT("|ID_SLIDER_Text2_2_TextRotation|ID_SLIDER_Text2_2_TextRotation=0");
Text2 = Text2 + wxT("|ID_CHECKBOX_Text2_COUNTDOWN2|ID_CHECKBOX_Text2_COUNTDOWN2=0");
The point of this list is to say, i will be checking and modifying the xml file if i see missing values or misspelled attribute names.
So please, make a copy and then use ver 19.
These fixes should eliminate those annoying message about some attribute is missing.
thanks
sean
jcmarksafb
Sean; I just downloaded 19 and installed, tried to run it and got "wxmsw294 ucd_gcc.custom dll was not found" error. I downloaded and installed a 2nd time and the same error.
smeighan
sorry guys, i upl;aoded my debug version rathe rthan the normal version. that is why the file size looked bigger.
i uploaded the correct file., give it another try
