Ok Problems again and I did clean my Glasses
bdeditch
Oroville, California
OK tonight I was going to try both of my P12R's in test mode. Hooked them both up, powered up and only one unit would work and the other one no way. I am not sure why not but I did take picture to show you what each one said, one is completely different on the main page than the other. I have named then 11 & 12. 11 was the one not working. I have starting the universes at 2 for using my LOR I have dumb strips on universe 1.
I am sure I do not have something set right, but what I have no idea. I am using the WS2811 strips and cut in half for a length of 2.5 M. I have them hooked up on the right end following the arrows on the strip. Here are pictures from 11 and XML file, this is the one that would not work. I also noticed that on the small 4 LED lights the bottom are lit up on 12 only one is.
<network e131='1' ubl='1'/>
<string num='1' act='1' type='WS2811' speed='3500' univ='2' slotstart='1' pixcount='25'/>
<string num='2' act='1' type='WS2811' speed='3500' univ='3' slotstart='1' pixcount='25'/>
<string num='3' act='1' type='WS2811' speed='3500' univ='4' slotstart='1' pixcount='25'/>
<string num='4' act='1' type='WS2811' speed='3500' univ='5' slotstart='1' pixcount='25'/>
<string num='5' act='1' type='WS2811' speed='3500' univ='6' slotstart='1' pixcount='25'/>
<string num='6' act='1' type='WS2811' speed='3500' univ='7' slotstart='1' pixcount='25'/>
<string num='7' act='1' type='WS2811' speed='3500' univ='8' slotstart='1' pixcount='25'/>
<string num='8' act='1' type='WS2811' speed='3500' univ='9' slotstart='1' pixcount='25'/>
<string num='9' act='1' type='WS2811' speed='3500' univ='10' slotstart='1' pixcount='25'/>
<string num='10' act='1' type='WS2811' speed='3500' univ='11' slotstart='1' pixcount='25'/>
<string num='11' act='1' type='WS2811' speed='3500' univ='12' slotstart='1' pixcount='25'/>
<string num='12' act='1' type='WS2811' speed='3500' univ='13' slotstart='1' pixcount='25'/>
<effect num='1' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='2' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='3' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='4' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='5' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='6' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='7' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BRG' null='0' repeat='0'/>
<effect num='8' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='9' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='10' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='11' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
<effect num='12' suf='A' act='1' pixstart='1' pixcount='50' rgbconv='BGR' null='0' repeat='0'/>
And for 12
<string num='1' act='1' type='WS2811' speed='3500' univ='14' slotstart='1' pixcount='25'/>
<string num='2' act='1' type='WS2811' speed='3500' univ='15' slotstart='1' pixcount='25'/>
<string num='3' act='1' type='WS2811' speed='3500' univ='16' slotstart='1' pixcount='25'/>
<string num='4' act='1' type='WS2811' speed='3500' univ='17' slotstart='1' pixcount='25'/>
<string num='5' act='1' type='WS2811' speed='3500' univ='18' slotstart='1' pixcount='25'/>
<string num='6' act='1' type='WS2811' speed='3500' univ='19' slotstart='1' pixcount='25'/>
<string num='7' act='1' type='WS2811' speed='3500' univ='20' slotstart='1' pixcount='25'/>
<string num='8' act='1' type='WS2811' speed='3500' univ='21' slotstart='1' pixcount='25'/>
<string num='9' act='1' type='WS2811' speed='3500' univ='22' slotstart='1' pixcount='25'/>
<string num='10' act='1' type='WS2811' speed='3500' univ='23' slotstart='1' pixcount='25'/>
<string num='11' act='1' type='WS2811' speed='3500' univ='24' slotstart='1' pixcount='25'/>
<string num='12' act='1' type='WS2811' speed='3500' univ='25' slotstart='1' pixcount='25'/>
<effect num='1' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='2' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='3' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='4' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='5' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='6' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='7' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='8' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='9' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='10' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='11' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='12' suf='A' act='1' pixstart='1' pixcount='25' rgbconv='BGR' null='0' repeat='0'/>
<effect num='12' suf='B' pixstart='1' pixcount='1' rgbconv='BGR' null='0' repeat='0'/>
<effect num='12' suf='C' pixstart='1' pixcount='1' rgbconv='BGR' null='0' repeat='0'/>
<effect num='12' suf='D' pixstart='1' pixcount='1' rgbconv='BGR' null='0' repeat='0'/>
For #11 thats not working....
the Effects are out of range because you have 1-25 in string config but 1-50 in effect range? Should be 1-25 in effect range?
I never took a screen shot of that I will check, thanks.
