Hi,
Quick question. How many WS2811 pixels can I run per channel on the Pixlite 16? It says I can run 1024 RGB Pixels per output. Will not let me run more than 340. Did they mean dumb RGB's?
Cheers,
Brad
If it is an ECO model 340 or 680 or something like that.
Older versions of xLights limited the output, I run 2020.44 and it is all good
Check the board setup with the Advatek Assistant. Make sure you have the latest version.
Little hint up to 680 for 40fps and 1020 for 20fps.
Nothing at the moment except for giving them a call/email there are always helpful I have heard.
I have a PixLite 4 ECO that does the same in the new firmware the old firmware was a bit less locked down.
