BrianJ
so I am hooking up everything for the final display and one of the outputs (7) is dead. I don't think I have ever tested it before so do not know what could have happened to it. I will get by fine for this year with it because I only need 10 of the outputs available to run everything as wired, and if need be I could rewire my candles to run from one output instead of the three they are using.
Has any one else had any issues with a dead output on a p12? I have checked all the fuses, and also checked at the socket and there is voltage and ground. I have also double checked all the settings etc and rebooted more than enough times
Any suggestions would be appreciated.
