PCA9685 to FPP and Xlights
christophe
Melbourne
Hi everyone, I need your help please.
I am trying to add some servos to my show using PCA9685. I will be running PCA9685 from a raspberry pi. I am not sure what I am doing wrong as I am trying to test the servo on xlights talking to the raspberry pi. Below are my settings on FPP (raspberry pi):
Settings on xlights:
Is there something I am missing?
Thank you
silver_ice
Based on your xlights screenshot you have defined 0 channels in there - is it auto sized? turn that off and just specify the 16 channel size manually
christophe
Melbourne
Thank you for your reply. I have updated the controller settings and unfortunately I still can't output to lights from xlights. Controller.JPG
I am not sure where I am getting it wrong. I have tried to find any resources online but there is not much info on servos out there.
Thank you
Martin Mueller
Light Addicted and proud of it.
Newtown CT
Before using xLights, have you used the FPP display test functionality? You should get it working on the FPP without xLights. In this way you divide the problem into smaller sections. If it does not work directly from fpp then you may have a wiring error.
christophe
Melbourne
Yes I did test it on fpp and it is working fine.
Martin Mueller
Newtown CT
Cool, one possible error spot fixed. I am not an xLights guy so someone with more xLights experience will need to help you beyond this point.
Skymaster
Crazy elf
Western Sydney
Is your DDP/E1.31 input page configured correctly on FPP to receive the network data from xLights?
christophe
Melbourne
Hello everyone I would like to let you know that I have managed to do it. I used the visualizer and push the configuration on xlights. If anyone needs help to set up their PCA9685, please do not hesitate to reach out. Thank you
