Peekaboo tombstone
djgra79
Cranbourne West
Last year I wanted to make one of these:
View: https://youtu.be/O6scAyuJCEU
But the mechanism is quite tricky (even original builder said so!) and house renos got in the way, so it was abandoned to this year.
My 2nd attempt at the mechanism worked OK at first but then decided to have an epic fail.
View: https://www.instagram.com/p/BXnMhnChP6F/?taken-by=evans_central_christmas_lights
So I replaced the old garage door motor with a 12v 10RPM geared motor such as these.
View: https://www.instagram.com/p/BYtyl2RB8wa/?taken-by=evans_central_christmas_lights
Next was to create a tombstone base to hide the mechanics and help weatherproof the motor:
View: https://www.instagram.com/p/BYsyMSbBibE/?taken-by=evans_central_christmas_lights
Next came some more lettering and starting the aging process (cracks and chips off edges), and the grey base coat of paint:
View: https://www.instagram.com/p/BY5jc_FhwvU/?taken-by=evans_central_christmas_lights
Painting the letters darker and wiping down excess paint to start the weathered look:
View: https://www.instagram.com/p/BY-q6NgBMt4/?taken-by=evans_central_christmas_lights
Then the drippy paint (watered down dark followed by some water to wash away parts) and then assemby, and we have a finished prop!
View: https://www.instagram.com/p/BZF2BqghCmv/?taken-by=evans_central_christmas_lights
All that's left is to pop a skeleton behind it, and attach the hands to the sides of the tombstone, and add in a couple of LEDs to light it all up at night.
What was the cause of the epic fail Graham?
It looks great btw.
Thanks.
If you looks closely, my original T-piece of conduit was actually 2 pieces dodgily (it's a word!) glued together. One of the bolts got a little too tight and ceased up, which just ripped the whole piece out and snapped the small bit of tin wood I was using as part of the linkage. SO I replaced the T-piece with an actual 1 piece t-piece, replaced the wood with another piece of metal bracket and also by using a smaller physical motor, the overall base size was reduced.
looks awesome DJ!
Couldn't you fashion a rotating cam (from wood?) to raise and lower that pipe? Far simpler than that linkage.
Thanks.
Ahhh. Lack of locknut on the top pivot and the self tightening effect and bucketloads of torque from the windscreen wiper motor could cause a massive fail.
looks awesome DJ!
That is another option yes, but hadn't really thought of it in this application. I tried to copy what had already been done in the original video which worked.
