If they are like the candy canes i build i have them connected together, so the bottom of the candy cane is where th power and data comes in and the top is where the extra cable is added to then connect to the second candycane.
So what im suggesting is using that 18guage cable as your supply to the pixels but also then connecting the 18 guage cable from the first to the last pixel. This way you eliminate some of the voltage drop created in the cane
---- pix1-----pix2----pix3-----pix4------pix5------ (candy cane)
|-----------------------------------------------------| (18 guage bypassing pixels and connected in series)
So basically you run the 18 guage in parralel with each cane so you eliminate the voltage drop through each candy cane as your not relying on the small cable that is connected between each pixel to then supply power to the second candy cane
