Thought I'd record a video showing the difference between pixel spacing and what different looks can be achieved.
In the below video I have 3 different types of pixel spacing when using something such as Boscoyo Chromatrim or mounting strip (this was my own home made coro strip, manually punched into 3mm coro)
* On the left is my existing (and soon to be replaced) 30/10 pixel strip. This strip has 3x LEDs per pixel and 10 pixels per meter.
* The top right section are nodes at 2inch spacing (~5cm) so this would end up being approx. 20 pixels per meter, essentially double the pixel resolution, but only 2/3 the number of visible LEDs.
* The bottom right section are nodes at 3in spacing (~7.6cm) so this would end up being approx. 13 pixel per meter. Only slightly better resolution than the strip but only 1/3 the number of visible LEDs.
When I'm at the bottom of the driveway the viewing distance is around 6-7m away. In reality my most common viewing distance would be parked across the road, so more likely 10-15m away.
Keen to hear people's thoughts on what they have used on their own displays and why. Its a topic that comes up a fair amount of times and I don't recall seeing a visual example of what the differences are, so thought I'd do this not only for my own benefit but for the wider community too.
View: https://www.youtube.com/watch?v=v10dbAiWlIA
