Pixlite + pixlite pro
Discussion in 'Advatek Lighting' started by julienLed, Sep 7, 2017.
  1. julienLed
    julienLed New Elf
    Sep 7, 2017
    2
    0
    Hello,
    I'm planning to buy a pixlite controller with some pixlite pro. I read that the pixlite pro have a 16 bit gamma correction that improve dimming response.
    I would like to understand how it's managed by the pixlite. because I will use it with mad mapper software but it work in artnet/dmx. As the DMX protocol only send 8 bit packets, I don't understand how it work to have a full 16 color grayscale.
    Sorry for the noob question, but I'm really new to electronics I develop interactive software and would like to use the full potential of those LEDs.
    thank for your help!
  2. bbayjohn
    bbayjohn Senior Elf
    Mar 4, 2012
    571
    26
    Batemans Bay
    Hi Julien & wecome to ACL
    Advatec lights and controlers are great and easy to use.
    Data
    • Ethernet input compatible with industry standard sACN (E1.31) and Art-net DMX-over-ethernet protocols
    • Onboard E1.31 to DMX512 output capability (no Art-Net to DMX)
    • Supports both Multicast and Unicast addressing
    • Supports IGMP allowing highly efficient data packet routing in large Multicast networks with many hundreds of universes
    • High refresh rates
    Power
    • Individually fused outputs and logic circuitry
    • Wide range voltage input
    • High current capacity outputs
    • Configuration free power connection
    Other
    • High power TVS (600W transient peak) providing external ESD protection on DMX interface
    • Remote temperature and voltage bank monitoring
    • Firmware upgradable remotely over the ethernet network via the easy-to-use ‘Advatek Assistant’ utility
    • Simple network setup and fast configuration via powerful Assistant utility that shows all controllers on the network at once
    • Advanced configuration options including start universe, start channel, null pixels, zig-zag, reverse pixels, RGB color order, pixel grouping, brightness control and more
    • Built-in hardware test pattern mode
    • Individual outputs with each connector supplying power and data over a single cable
    • Easy to use pluggable screw terminal connectors on all channel outputs and data interfaces
    • Currently supports PixLite Bright™ series (12-bit) and PixLite Pro™ series (16-bit) pixel strings in addition to numerous other pixel protocols (TLS3001, SM16716, LPD6803, WS2801, WS2811/12/12B/APA104, TM180x, MBI6020, INK1003, APA102, SK6812, UCS1903, MY9221, MY9231. .) Note: one pixel type at a time per controller
    PixLite controllers can be used with any software that supports the industry standard Art-net or sACN E1.31 protocols (xLights, Vixen, Light Show Pro, HLS, Light-O-Rama, Light Jams, Light Factory, ArKaos, Madrix, MadMapper, vvvv and others.) - coppied form advatec
    Most people here use the program listed first, I hadnt even heard of Light Jams, ArKaos or MadMaper. Mad maper looks to be more suited to projectors
  3. OP
    OP
    julienLed
    julienLed New Elf
    Sep 7, 2017
    2
    0
    Hello,
    thanks for you answer, but I would like to understand how the pixlite manage the 16bit grayscale mode. Do I need to change the clock on the advatek assistant if so, what would be the frequency to select the 16 bit mode on the IC of the LED string?
    I read somewhere that the chip used for the pixlite pro led strings is the MY9231. (up to 16bit grayscale)
