Planning a small display around the viewing angle
One simple starting point for a small yard is to sketch what visitors will see from the footpath, not just from the front door. Two props that look nicely spaced up close can overlap from across the street.
Leaving a clear gap around a deer group or small tree also gives you room to reach cables and fix things later. What tends to decide your layout first—the viewing angle, access, or available power points?
