Plasma Icicles 2.0
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by plasmadrive, Jun 8, 2017.
  1. plasmadrive
    plasmadrive Full Time Elf
    Jan 12, 2012
    243
    38
    Elk Grove, CA
    I have Ray making me some Plasma Icicles 2.0.
    The originals I made a few years back curl to the back and that really annoyed me. So now I have come up with these. They are rigid PCBs that have the DO return out the same end as the DI and power. So no longer do you need to run the wire up the back side of the PCB in the silicon sleeve.
    I also wanted to change to all one length..
    So here is the prototype. Ray will be making and selling them. I had him use JST connectors because of the size and ease of use. For my personal set, I will be using dielectric grease on the connectors and they will be under the eves of the house, so no direct rain.
    I also have an extended sleeve at the top to help with the mounting so they will all hang at the same height..
    I also found out that the DC converters I use from Prodcdc are able to stand being all on the same output buss using the same input supply. What that means to me is that I can put as many of these as I can support in a line and feed the data as required and pop power in any place I want using the 2.5mm plugs.
    I will post more in the coming weeks if anyone is interested.
  2. lytnin
    lytnin Full Time Elf
    Jul 26, 2010
    103
    12
    North Richmond NSW
    Looks nice. How many LED's per Icicle?
  3. OP
    OP
    plasmadrive
    Jan 12, 2012
    243
    38
    Elk Grove, CA
    Mine are 1/2m long and 16 pixels..
  4. OP
    OP
    plasmadrive
    Jan 12, 2012
    243
    38
    Elk Grove, CA
  5. foodi
    foodi New Elf
    Aug 31, 2014
    20
    6
    maryborough victoria
    that cool as 2weeks ago i go him to make me 30/60/90 cm 30 of ea
    plasmadrive likes this.
  6. OP
    OP
    plasmadrive
    Jan 12, 2012
    243
    38
    Elk Grove, CA
    Did you ask for this using the rigid PCB? I have been working with him on this for months.. The first two rounds he made them wrong. This time he did it just right..
  7. battle79
    battle79 Full Time Elf Generous Elf
    Dec 8, 2012
    401
    3
    Chirnside Park, Victoria, AU
    Nice! Too back I already just bought 4/5/6 drop pixels icicles, these would be a great alternative.
  8. OP
    OP
    plasmadrive
    Jan 12, 2012
    243
    38
    Elk Grove, CA
    A couple of days ago the New Plasma Icicles 2.0 arrived. (Very well packaged). I tested all 200 of them and they are great!
    Something unexpected however. When testing I noticed that the current draw was not as high as expected. Each pixel only draws 33-38mA (full white using a little tester to drive them) instead of the 55-60mA I was expecting. This means approx 2.2amps per group of four icicles. I don't really notice any brightness issues, but I haven't put them side by side with the original Plasma Icicles. Being that everyone turns them down anyway, I see this as a very positive thing.. It helps my current budget substantially. For all 200 of them plus the burn from the DC converters, I only need about 625 watts total from my main 24v supplies.
    These strips were made so that they could be single sided or double sided. I chose single sided. Could be they use that lower current setup to accommodate the two sides without killing the current budget.. I don't know, but I like em this way just fine.
  9. tooms
    tooms Full Time Elf
    Jan 2, 2015
    111
    20
    Kalgoorlie
    Has anyone asked for a 12v version ?
  10. OP
    OP
    plasmadrive
    Jan 12, 2012
    243
    38
    Elk Grove, CA
    Not sure. The issue for me is that there are only 16 pixels per Icicle. If you made them 12V that would really only be 5 pixels since the 12v strips are 3 LEDs per pixel set.
  11. Cologne LED
    Cologne LED Cologne LED
    Jun 29, 2018
    22
    1
    Cologne, Germany
    Looks Great.
