Play from selection
BundyRoy
Is there a way to set the default for the play range to be "play from selection". I'm getting tired of doing it manually each time I start up and can't seem to find it in preferences.
Thanks.
By default at startup it will play the full sequence. You can change it between full sequence, selection, visible screen and maybe 1 or 2 other options as well as play once or loop..
BundyRoy
So I gather you can't change the default setting of full sequence at start up to play from selection. I can change it manually each time but would like the default setting to be something other than play full sequence.
