battle79
Edit: So I was only powering from the little connectors on the side (as I'm not using the first 16 ports yet) and I noticed the voltage drop everytime I loaded up the unit with packets. Ran a large cable and plugged into V2 and moved the jumper. Now it seems to be good, at least so far. Hurray!
Hi All,
My F16v3 was hard to set the network for and took 4 attempts before it held it's network address and didn't reset to default.
After this it seemed fine for a while, but now it seems to randomly lag behind all my other controllers at times.
Also occasionally it seems to drop off the network as far as AngryIP and web browser are concerned, but still outputs to lights when the PI is outputting.
I have everything set up as unicast, Everything is on the same 192.168.111.0/24 network.
Really at a loss as to the problems. Basically, has anyone else run into similar issues and found the cause.
Alternatively, does anyone in Melbourne have a spare f16v3 I can test with to see if that is the problem. Happy to collect and drop off anytime required.
Regards,
Rowan
Hi All,
Regards,
Rowan
