JordoLights
Hello all, I have been browsing and reading threads and found out that in order to avoid the controller fuse to blow when power injecting, you could cut the positive wire so that power doesn't "flow back" to the controller which could overload the fuse and blow it. So the idea is to start a fresh line of positive - this would come from a fused distro board. My question is, do I keep the negative wire running from the controller all the way to the last pixel in the one output? Or do I also cut the negative wire where I cut the positive wire?
Note: Only using 1 power supply for controller and lights.
Another question, my power supply has 3x V+ and V- outputs. My power distro board has 2 inputs. Is it okay to piggy back these inputs onto 1x output (V+ and V-) from the power supply?
Thanks in advance.
Thanks in advance.
