Power Injection Question
Bmac99
This is my first year working with pixel lights and got to a part of my setup that requires power injection. I’m using a Falcon F16v3 and 12V power supply. My garage outline requires 130 pixels and I’m about 25 feet from my controller box containing my power supply. I have 2 empty/unused ports on my F16. Can I simply plug in a pigtail into one of those ports (just positive and ground while leaving data unplugged) and run a line from that unused port connecting to the end of the pixel string to inject power? Or do I have to go directly from the power supply? Thanks for your suggestions.
For only 130 pixels it should be fine on one port on 12V.
Either will work. Most individuals I think would take it from the power supply through a fuse. Taken from the controller, the on-board fuse will handle the protection. From the supply not the controller would remove any wiring rearrangement if your display grows and the ports would be needed.
I’ve got a string of 12v that is 192 pixels long and I run it at 30% without power injection. It gets scratchy when I test above 80% but I don’t go that high in the show anyway so I don’t worry about it.
I think, from reading the full description of the setup, there is only 1 power supply and there are only 2 ports on the F16 left. That indicates to me there are way more pixels running off that F16 than just 130. At 100% a 30A PSU (12V 360W) can power about 500 bullet nodes. Obviously, that's all on, all white... but you get the point.
