Power Injection question
sck1ng
I was wondering that if I had a single PSU feeding a string of 200 pixels and had to power inject at the end of the string from the same PSU, do I only need +V connected or should I also connect the GND?
You need to connect both the +ve and Gnd at each end.
That's right you need +ve and ground to complete the circuit, if easier you could inject in the middle at 100 pixels for same result
Im looking at something similar and wondering if this is correct:
6 arches, each with 75 pixels.
Each set of 2 arches will be off a single output of a pixlite, e.g. output x (power and data) to Arch y (y=1, 3 or 5). I need to feed power back in to the ends of each set of 2 (arch 2, 4 and 6). Can I just run a separate feed of + and - for each of these 3 from the same supply as powering the pixlite?
[edit: previous was not entirely clear (or correct - it has been a while since I've put these together.)]
