grahami2006
I have some Bunnings lights that I want to control from dc. They are rated at 31 volts. What size power supply will I need?
grahami2006 said:I have some Bunnings lights that I want to control from dc. They are rated at 31 volts. What size power supply will I need?
Eddy on the power supply/flasher unit it says PRI 100-240 volts.ɟɐsʇǝppʎ said:grahami2006 said:I have some Bunnings lights that I want to control from dc. They are rated at 31 volts. What size power supply will I need?
That will depend if they are AC or DC lights. So when its says 31 volts is that using DC or AC volts
You may need a picture as it doesnt state if its AC or DC output which make the difference.grahami2006 said:Eddy on the power supply/flasher unit it says PRI 100-240 volts.ɟɐsʇǝppʎ said:grahami2006 said:I have some Bunnings lights that I want to control from dc. They are rated at 31 volts. What size power supply will I need?
SEC 1 Output 31V
SEC 2 Output 31V
