hi guys,
i have a DSE 0-15V 2 amp power supply to power my Ren64. I've never played around with anything electrical before so I just want to get some noob advice so i don't fry anything.
the bottom two lugs on the power supply are for input of 240V, which i have a 2 pin power cord to hook up to. does it matter about which cable from the cord goes to which lug for the input because there is nothing marked on the power supply and no leaflet or anything that came with it?
and for the output. if i want 6.3V out, i assume i use the 0V and 6.3V lugs to get my required voltage? does it then matter about which of those 0v and 6.3v connections goes into which tab on the Ren64 board?
once this is done i can fire up the board and do some testing.
i noticed on the board there is a test point TP1 but i couldn't find any other test point or instructions on what to test for, any ideas?
thanks, fj
thanks, fj
