problem pixels??
candlelight
Cleveland, Ohio
have this feature, but am having trouble tracking down where the problem is. couple of pixel strings seem to be giving me problems. don't think its voltage because i have two of these built exactlythe same and the other one works fine.
have already swapped out controller - didn't make a difference
2801 pixels, 12v
every two rows are connected with data and clock, so looking at picture there are basically 6 groups of strings on the board.
power injected every row (every 20 pixels)
problem pixels is always in the same area, but can vary a coulpe of pixels either direction
candlelight
Cleveland, Ohio
one more pic...
problem seems to be in row 4
and row 7 and 8 (which are on the same data/clock line)
thanks for the help!
lithgowlights
Also... The rows that seem to fail - are they failing about 1/2 way down the line, ar a little less? If so check the power injection at the far end - it may be reversed,
candlelight
Cleveland, Ohio
one more pic, doesn't really help but in case u want to see my setup
using j1sys, p12
power is only supplied from right side, but attached to every row
checked connections and all looks correct????
kane
using j1sys, p12
checked connections and all looks correct? ???
Sounds like a couple dodgy pixels to me - I've had situations like that before. I have usually found that it's either the first pixel that is displaying incorrectly that's dodgy, or the one before.. (I've usually found it's easier to just take 2-3 out, and replace with 2-3 from my spares)
Do you have any spare modules?
candlelight
Cleveland, Ohio
yeah i have some spares. i was thinking about that last night, might be easier to track down if i replace two pixels either side of where the problem seems to be occuring... thanks
I always replace pixels in pairs, so i replace the first one that is faulty and replace the one before that. More times than not it is the output of the one working that is at fault, but this could have been caused by an input issue from the next one, so best approach is to change in pairs.
Crazydave
[font=tahoma, sans-serif]does the j1sys, p12 board have an option to produce a test pattern/chase independent of the software?[/font]
Yes it does, you can refer to page 29 of the ACL P12R manual which shows you the dip switch settings that enable the test pattern and also how the pattern works
In a nut shell it is Dip switch 4 turned on to give you the test pattern
Crazydave
This should help identify which pixels are acting up.
