BigRedNole
First off, I am not sure if this is the correct place to post this issue. I am hoping it is. I am just starting to design my layout in Xlights. The first prop I am testing is a 480 pixel mini tree from Pixel Paradise. I am using a Falcon F16v3 to run the project. Below are the things I have done to test things out and points to the Tree setup in Xlights.
Potential Issues:
			Potential Issues:
- My laptop took a spill from a 32oz drink. Everything appears fine, but you never know.
- The Falcon F16v3 has Port 1 completely dead. 2-16 function fine at least from the Falcon test and Xlights test.
- From Falcon test and Xlights test, all 480 pixels light up as the should in all testing
- Pixel 479 will sometime light up a solid wrong color and stay that way. Pixel 480 will not turn on at all.
- Tree: Degrees 220; Rotation 3; Spiral Wrap 0; Bottom/Top Ratio 6; Perspective 2; Strand Direction Vertical; # Strings 2; Node/String 240; Strands/String 12; Location Bottom Left
- Setup is from the instructions from Pixel Paradise
- I have power injection on the last strand to be sure there is more than enough power going to all pixels (12v). In just the tests, there is no power issue so there shouldn't be with Xlights tree model.
- If I increase the number of pixels in Xlights to say 242 nodes per string, all pixels light up (484 pixels instead of 480). This does not solve the problem because those extra pixels in the nodes will run into the star on top.
