nato595
Let's do this!
Hello!
Can anyone please describe (or better yet, illustrate) the correct setup for wiring up a 12 strand pixel tree with the following specs?
12 strands of 60/M 12v strip (max draw 6A / 72W per strip) .
3 350W 29A power supplies.
1 ECG-P12S controller wired up to pass power + signal through each port.
By my calculations individual strips are OK to be powered from each port of the P12, but all 6 strips together (36A) exceed the 30A max per bank.
Currently I have one power supply supplying one bank of the P12, a second power supply powering the second bank, but what do I do with the third?! Do I need to connect each PS to each other and use the third PS to just feed power only to 4 out of my 12 total strips directly and use the P12 to power the other 8 strips (4 from each bank) to even things out?
Am I over thinking this?
Currently everything generally "works" but I am experiencing some flickering during high output scenes so I'm guessing I do really need the third PS...
Please help, I'm a week behind on kicking off my show!
Thank you!!
Thank you!!
