Raspberry Pi to switch on/off power supplies
Stirlo
Hi all, new comer here. Planning my show for next year just starting to order my gear.
Looking into how to manage the 240vac side of things, would like to have the raspberry pi using fpp to control a contactor to switch on the 240vac which supplies the power supplies via a gpio pin of the raspberry pi.
Has anyone done this before and could give me some tips on how to do this.
Dont yet have my hands on a raspberry pi to test anything. Have read the manual but not really clear there is a section towards that back which mentions scripts and gpio on/off??
I just use a timer that plugs into the power point and use it to turn on the power supplies about 2 minutes before the show starts then turn them off about 5 minutes after it’s finished. By the end of the month there is a couple that are around 30 seconds out which is why they start a few minutes early.
While it's easy enough to control a relay via the GPIO, don't use one of the $5 eBay relay modules to switch the mains directly. You could use it to control a larger contactor / relay with a DC coil though.
Yeh fully understand requirements when comes to switching the 240 side of things, but more looking for how to do it via fpp
It's really as simple as assigning the GPIO pin an FPP channel and it just works. The relay becomes a single channel controlled the same way the rest of lights are.
