Have read and reread 101 manual and browse lots of threads, now is the time to jump in, but at first with a simple project ??
Have a Santa/chimney wire frame that had AC rope light now dead, want to replace it with low voltage lights in three configurations.
Chimney in white LED light that will be on all the time.
Bottom and top santa both in red led, bottom one to be ON then Off as top santa frame comes on and then fades, sequence then repeats. Sounds simple no music etc.
I think I need
One string of white led lights say 8mm dumb led
Two strings of red or RGB smart LED as need a fade effect
Switched power supply
Controller to operate the display
Something to run the controller everything so far seems very complicated,
Am I on the right track ?? as I said this is a beginning project
Thanks in anticipation
Greg
I think I need
Greg
