RBG channels swapped between xlights and F16
Discussion in '101 Display Basics' started by Doctor_007, Aug 27, 2017.
  1. Doctor_007
    Doctor_007 Apprentice Elf
    Apr 28, 2017
    71
    18
    Toowoomba
    Hi All,
    I have a weird issue where I'm test running sequences in xlights and outputting to my lights and everything is fine with correct colour order (RBG) . However, when I run sequence through FPP the channels are swapped BGR?! I have the lights setup in xlights as RGB nodes and on the F16 also order is RBG. Any ideas what could be going on?
    Thanks,
    Matt.
  2. OP
    OP
    Doctor_007
    Apr 28, 2017
    71
    18
    Toowoomba
    The other weird part is if I test the channels through the F16 they are correct colours. So maybe something wrong in FPP for it to swap them somehow?
  3. djgra79
    djgra79 My name is Graham & I love flashing lights! Generous Elf
    Dec 27, 2011
    1,186
    359
    Cranbourne West
    If everything is correct when outputting to lights via xlights, another test is using da_e.131.
    But it does sound like the issue lies in FPP somehow.
  4. OP
    OP
    Doctor_007
    Apr 28, 2017
    71
    18
    Toowoomba
    Thanks @djgra79. Thinking at this stage the only way around it is to change it in the controller. It works that way but don't think I should have to do that.
  5. darylc
    darylc 404 darylc not found Global Moderator Generous Elf
    Dec 8, 2012
    531
    132
    could be an off by 1 or 2 channel problem between fpp/f16 configs
    Doctor_007 likes this.
  6. OP
    OP
    Doctor_007
    Apr 28, 2017
    71
    18
    Toowoomba
    Thanks @darylc. That might explain it actually. Will check this out as it has to be something silly that I've missed like that.
  7. Kitman
    Kitman Full Time Elf
    Oct 25, 2014
    379
    45
    Munno Para
    I had the same kind of issue, one of my strings of icicles was just weird colours and I couldn't figure it out until I looked at the controller and saw that I had the start channel of the string of icicles set to the same channel as the end of the last string made everything very weird.
  8. scamper
    scamper Senior Elf
    Jan 5, 2014
    978
    125
    collie
    A little off topic, but you realise you are using the "Vixen" logo as your profile pic yet you are using Xlights.
    I went to jump in to help, then realised I probably know nothing about your problem :confused:
  9. OP
    OP
    Doctor_007
    Apr 28, 2017
    71
    18
    Toowoomba
    Lol. @scamper, sorry I can see how that would be confusing! I'm actually using and testing on both. Just working in xlights at the moment.
