smeighan
Release 4.0.12
4.0.12 Apr 2, 2015
-- enh (gil) Render Morph effect into background of effect layer. This follows on ON and COLORWASH
-- bug () Add show directory to SETUP tab #156
-- bug () Undocking panels for first time - not showing complete panel #147
-- bug () Edit Display Elements window not full view #129
-- bug () Text element with Horizontal matrix and output to lights enabled - Crash #127
-- bug () Resizing effects then deleting - Effect still shows in preview #125
Gil had this comment on his changes for Morph "Since Dan already laid the ground work for effect backgrounds
I was able to code up the Morph in about 10 minutes. I'm currently not handling when they clip on the
window edges so I'm try to fix that and then check it in. Most of these I used white for the head except
for 2 in the middle you can see the head color transition."
I have included a picture Gil did showing how his morph effect now displays in the sequencer grid.
4.0.12 Apr 2, 2015
