smeighan
4.0.30 May 13, 2015
NOTES FROM DEVELOPMENT
(Dkulp) * Detect ramp up/down when converting to effects
(Dkulp) * IF the effects panels are disabled (for example, while rendering and saving),
we cannot update the effect as disabling the controls changes the effect strings.
(Gil) * Draw Timing lines last. This makes a timing grid look better when selecting 25,50ms.
(Gil) * Use original effect duration for paste if no timing track is active.
(dkulp) * Fix problem of "To Center" checkbox on text always being turned off
(dkulp) * Add the alpha channel handling to text effect
(dkulp) * Re-render range when effect moves
(dkulp) * More slider<->text updates. Dan is adding text boxes to all effects that have sliders. This allows entering exact values
ISSUES CLOSED in 4.0.29 and 4.0.30. See https://github.com/smeighan/xLights/issues
-- 4.0.30 May 13, 2015
-- Three channels in Custom Model when selecting 4 Channel RGBW #216
-- 4.0.2x Tall custom model causes Ok, Cancel Appearance buttons to move out of view, clickable area #213
-- Unable to change model on lengthy models #202
-- Nutcracker Timing Mark Import Failure #225
-- Enhancement - Models - Arches - single color #136
-- fseq Save Directory doesn't save to location specified. #190
-- Test tab requires that XL4 be restarted to see the new network configuration in 4.0.18 #211
4.0.30 May 13, 2015
