Release Release 4.0.32, lots of bug fixes
smeighan
4217 Greenfinch Dr CO 80126
Lots of bug fixes in this releases
XLIGHTS/NUTCRACKER RELEASE NOTES:
4.0.32 May 19, 2015
-- bug(dkulp) Rename the element in the loaded sequence on model rename. Fixes #223
-- bug(dkulp) Fix problem with overlapping effects that both specify fadein or outs causing interference
-- enh(dkulp) Use On effect for scenes when possible instead of colorwash
-- bug(dkulp) Don't call SetString on a sorted listbox. Fixes #217
-- bug(dkulp) Fix an issue with multi level stars with Single Channel types
-- enh(dkulp) Add double-click to row headering for expand/collapse strand/nodes
-- bug(dkulp) Fix RGBW
-- bug(dkulp) Fix crash on import of Conductor file. Fixes #226
-- enh(dkulp) Add Vixen 2.x to import capability
-- enh(dkulp) Add hlsIdata to import capability
-- enh(dkulp) Move Import capbability to new Import menu
-- enh(dkulp) Add abiltiy to play audio sequences at 3/4, 1/2, and 1/4 speed
-- enh(gil) Morph update. Improved position calculation. Added support for up to 4 tail colors.
Added repeat and skip count options. Added choice to quickly create 8 different morph types.
Removed Use Head Start Color for Tail Start and Use Head End Color for Tail End.
Added stagger option to allow morph repeats to each have a delay.
-- enh(gil) Morph: * Finer resolution for stagger option. * Allow negative stagger for morph.
Nice work Sean and the other guys working on this.
Out of curiosity is there and hope or plans to add a feature similar to LSP where you can run your mouse over a section of the audio waveform and the lights and grid show what's happening during that time. It's a great feature for picking transition points. I "think" that LSP call it washing.
Alan
I had to edit as I had guts rather than guys. Maybe that was a Freudian slip as the guys were working their guts out. :)
Washing, scrubbing. I knew it was something to do with womens work :smirk:
gerry said:
Hi Alan
Did you mean scrubbing ?
richardd
Geraldton
Alan you are going to have to replace my monitor after I to a sip of coke and sprayed it all over my monitor after reading your post
gerry
Surrey Hills,Melbourne
Living dangerously (Alan) is all I say !!
Having said that , I do like the look of xlights now - it looks quite similar to LSP except that it is significantly faster to render and is much easier for a layman to use then the current version of LSP is.
