smeighan
This release is the accumulation of content over the last week while I was on vacation.
Thanks again to Gil.
4.1.10 Jul 8, 2015
-- enh(gil) Add preview of image to the Effect Assist window for Pictures effect. More to come for this effect.
-- bug(gil) Selecting a single cell with any drag movement of the mouse was causing invalid effect end time when placed.
-- enh(gil) Add SaveAs to the File menu.
-- bug(gil) Fixed effects dropped on grid were not previewing.
-- enh(gil) Update View -> Windows so that Perspectives, and Display Elements windows work and add Effect Assist Window.
-- enh(gil) Add settings options for how the effect assist window behaves.
-- enh(gil) Added new panel to help in defining Morph positions. Will be expanded for other uses later.
-- enh(gil) Automatically initiate Render All after adding or modifying data layers when dialog is closed to remove confusion.
-- enh(gil) Add ability to Delete Views.
-- enh(gil) Allow timings to be added/removed from views. This info remains local to each sequence not stored as part of the view
since not all sequences have the same timing names.
-- bug (sean) Fix README.windows that got overwritten. These are instructions for compiling our code under windows
4.1.10 Jul 8, 2015
