smeighan
Release 4.2.11
Some bug fixes.
For the first time this year, I have created a new effect. In 2015 Dan and Gil have been doing all the work so far. I have a few more new effects I want to add in the next few weeks. New effect is called Plasma. I added the effect into Butterfly as Effect Style 6,7,8 and 9. Lots of sliders can be added to this effect but i thought i would get it out since some may want the Black/White effect for Halloween.
I tested a 96x80 horizontal matrix. Save took 8.5 seconds so it is pretty efficient.
Follow these links you will see animated versions. I changed speed slider to three values from slow to fast. Only style and speed work on Style effects 6,7,8,9 (Plasma Effects)
http://nutcracker123.com/nutcracker/images/plasma8.gif
http://nutcracker123.com/nutcracker/images/plasma9.gif
4.2.11 Sep 20, 2015
-- enh(sean) New effect Plasma. Access this through butterfly. Select Style 6,7,8 or 9
-- bug(dkulp) On a new sequence, make sure the timer is restarted with the right speed
-- enh(dkulp) Allow a custom color for each phoneme in faces.
-- enh(dkulp) Allow multiple face definitions for every model type, not just matrix. Fixes #357.
Some bug fixes.
4.2.11 Sep 20, 2015
