smeighan
release 4.2.14. This release has lots of content.
Bug fixes
New effect class Lightning
New tiled pictures as choice in Pictures
-- enh(ChrisD) Add application launcher for linux
-- bug(ChrisD) New timing dialog should be titled as such (partial fix for issue #377)
-- bug(gil) Buttons will now re-enable after an LSP export model operation.
-- enh(Keithsw) New feature in pictures, tiled pictures
-- bug(gil) Fix potential crashes for all imports where models may be hidden.
-- bug(gil) Fix LSP import effects when a target model is hidden.
-- enh (sean) New effect class Lightning
-- bug(gil) Sequence SaveAs was not saving XML in new directory.
-- bug(gil) Remove fixed attribute for timing track converted to papagayo timing.
-- enh(gil) Add LOR conversion option to show verbose channel mapping.
-- enh(Keithsw) Updated tile code to support x/y offsets in Picture effect
-- bug(dkulp) After deleting an effect, if you hit Up/Down, crash will result
-- bug(dkulp) Use native ObjectC code for clipboard paste for custom models to support pasting from Numbers
-- bug(dkulp) Click on a "node" may not hit test properly if an effect exists on the model or strand layers
-- bug(dkulp) Prevent effect from being resized so start is < 0ms which prevent effect updates/rendering/etc..
-- enh(dkulp) Add option to twinkle to re-randomize the color after each twinkle
-- enh(keith) Added tiling options to picture effect
-- bug(sean) Fixed bottom row of plasma. Bug was the bottom row was copied from top row
-- bug(ChrisD) Fix issue #368 - missing OK/Cancel on Schedule Playlist
Bug fixes
