Release release 4.2.5 & 4.2.6
smeighan
4217 Greenfinch Dr CO 80126
Release 4.2.6.
Gil has fixed some stuff, Thanks Gil!
4.2.6 Sep 02, 2015
-- bug(gil) Fix morph row/column calculation for large model sizes
-- enh(gil) New model groups default to "minimal grid".
-- enh(gil) Add scrollbars to lower windows in Model Groups dialog. Fixes #350.
-- enh(gil) Increase window frame model bottom limit. Fixes #351.
4.2.5 Aug 29, 2015
-- enh(gil) Add Marquee effect
-- bug(gil) Fix crash when renaming model without sequence open.
-- bug(dkulp) Implement an "Auto" mode for Eyes for Coro/Image faces that will blink roughly every 5 seconds on a rest
-- bug(dkulp) Fix crash if face effect dropped on a strand or node
AAH said:
Is there any work happening on a possible LOR (and maybe LSP, Vixen) quick transition setup as I mentioned on
http://auschristmaslighting.com/forums/index.php/topic,7729.msg69654.html#msg69654
Great work as always Sean, Gil, dkulp, et al.
yes, i have a prototype web page.
it takes a LOR lcc file and creates
xlights_rgbeffects.xml with all models and views
xlights_networks.xml with a network setup
The issue is different lcc files have stuff in them that i need to parse. some people have 4 setups for the same channel. I am trying to build a form where you click on what you want.
so , yes. progress.
I also started looking hwo to parse the lee files. part of it is easy, part is hard.
i am pretty busy the next 7 days, so ill see if i can get the first prototype out to those who sent me their lcc/lee files
You're the man Sean :)
I don't think my .lee file had duplicate channels but it did have stuff shuffled all over the place.
