RGB and LOR channel numbering
yzguy96
Chicago
Hi,
Is there an easier way to reconfigure all my channels in LOR? When I originally sequenced I added too many channels to my windows now I need to delete 10 and renumber so everything is correct. Do I create a new sequence with the right channel configuration save and export the channels then import into my current sequence?
I've found the easiest way to delete lots of channels is to turn them into a group and then just delete the group.
thanks, any tips on renumbering the channels? since i am deleting 10 pixels now everything moves up 30 channels on first string then 60 channels on 2nd...etc
Renumbering is 1 of my pet hates in LOR. Depending on how many channels you need to do and how you need to arrange them then you may be better off just creating a new sequence with the channels that you want in the order you want and then just cut and pasting the sequence across.
