RGB Floods DMX IDs in LSP
cwbotner
Winsted, MN
All;
Some Of my Fllods are 5 channel, and some are 8 in the intruction sheets that came with the products.
Some are R, G, B, W, and strobe plus 3 "program" channels. So When setting up my DMX Floods in LSP, can I just set up 5 going to be used insted of 8 total, and on the 5 channel, just set up the RGB in LSP?
Thank you.
There's not really enough info there to give a categorically correct answer. My assumption would be that for instance strobe 1 will have 8 channels. red, green, blue etc. For you to use them you will only need to assign 3 channels in your sequencing software. What you do need to do is NOT assign the extra channels to any other lights as when you are going to control them the floods could be getting signals that match up with the strobe channel for instance.
