sielbear said:At full tilt (white) this would draw 3 amps per 5 meter strip on the common leg. Would I not need to worry about overloading the common in this scenario?
The common active is not switched and as such is connected to the common bus on the baord, so its not subject to a 4 amp limit. I would though connect the common to 2 diiferent channels on the controller, say channel 1 & 2 common but you would be using 3 switched channels anyway for red green and blue
