- Thread starter
- #1
Well my RGB strings arrived today.
These are a classic string with all LED's being controlled together.
They require a 5v DC power by default and came as 50 RGB LED strings.
[smg id=32]
Two 50 count strings straight out of the box
The spacing between modules is 75mm or 3 inches, giving a 50 count string a overall length of 3.75M or 12 feet.
[smg id=33]
Each Module is about 12mm wide and a 8mm RGB 4pin LED is used.
[smg id=34]
looking at the wire end shows that whilst the outer silicon(plastic) module is closely molded to the wires they is no sealing between the two 4 wire groups, a quick injection of silicon sealant should work well, yet to test
[smg id=35]
............ continued post 2
[smg id=32]
[smg id=33]
[smg id=34]
[smg id=35]
