RGB Strings
tuppetsdad
Funding & Tech Support
Melbourne
Following on from visiting the show in Guangzhou have ordered some RGB string lights.
Spec
Type RGB String with RGB white balls
Voltage 24 VDC
Rating IP 66
Light diameter 16 mm
Spacing 100 mm
Length 5000 mm
Wires black with UV rating
Connectable (max 5 lengths joined together with 4 pin connectors each end)
Connecting cable 4 wire 2m with connector one end.
Have tested them and they are a bit different looking than the usual LED strings. We will try some this Christmas.
Today have wrapped a 5m string around one of our verandah posts and it looks pretty nice when running.
Some pics below
Ryan will be getting some of these soon so see if he "likes" them...in transit Ryan should have Thursday
I would "like" to see them arrive to see if I "like" them to get more to complete the porch pole plan, so that I can "like" the overall effect.
So they're arriving to you on Thursday?
... "like"
In hong kong TNT despatch center so Thursday is looking good Ryan.......and you had better really LIKE them!
